Qanitro komentarz 4 lipca 2009 Autor komentarz 4 lipca 2009 Microsoft ® Windows Debugger Version 6.6.0003.5Copyright © Microsoft Corporation. All rights reserved.Loading Dump File [C:\WINDOWS\Minidump\Mini070409-01.dmp]Mini Kernel Dump File: Only registers and stack trace are availableSymbol search path is: *** Invalid ******************************************************************************** Symbol loading may be unreliable without a symbol search path. ** Use .symfix to have the debugger choose a symbol path. ** After setting your symbol path, use .reload to refresh symbol locations. *****************************************************************************Executable search path is: ********************************************************************** Symbols can not be loaded because symbol path is not initialized. ** ** The Symbol Path can be set by: ** using the _NT_SYMBOL_PATH environment variable. ** using the -y <symbol_path> argument when starting the debugger. ** using .sympath and .sympath+ **********************************************************************Unable to load image ntoskrnl.exe, Win32 error 2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeWindows XP Kernel Version 2600 (Service Pack 2) MP (4 procs) Free x86 compatibleProduct: WinNt, suite: TerminalServer SingleUserTSKernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700Debug session time: Sat Jul 4 16:32:12.187 2009 (GMT+2)System Uptime: 0 days 0:09:03.816********************************************************************** Symbols can not be loaded because symbol path is not initialized. ** ** The Symbol Path can be set by: ** using the _NT_SYMBOL_PATH environment variable. ** using the -y <symbol_path> argument when starting the debugger. ** using .sympath and .sympath+ **********************************************************************Unable to load image ntoskrnl.exe, Win32 error 2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeLoading Kernel Symbols...................................................................................................................Loading User SymbolsLoading unloaded module list.........*** WARNING: Unable to verify timestamp for hal.dll*** ERROR: Module load completed but symbols could not be loaded for hal.dll******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************Use !analyze -v to get detailed debugging information.BugCheck 9C, {0, b834c050, b627c000, 135}***** Kernel symbols are WRONG. Please fix symbols to do analysis.Followup: MachineOwner--------- to najnowszy mini dump, zaraz zwieksze napiecie ram i dam znac czy cos dalo... Nic nie dalo, chociaz w sumie tak - nie pokazal sie BSOD, ale pojawialy sie jakies obrazki, byly troche inne kolory, az sam wylaczylem...
Gość komentarz 4 lipca 2009 komentarz 4 lipca 2009 Nic nie dalo, chociaz w sumie tak - nie pokazal sie BSOD, ale pojawialy sie jakies obrazki, byly troche inne kolory, az sam wylaczylem... No to chyba karta sypie artefaktami... chociaż lepiej zrób jeszcze tego memtesta i przetestuj kartę w drugim komputerze .
Qanitro komentarz 4 lipca 2009 Autor komentarz 4 lipca 2009 (edytowane) No to chyba karta sypie artefaktami... chociaż lepiej zrób jeszcze tego memtesta i przetestuj kartę w drugim komputerze . na drugim jest feel II 350W - a w tej obudowie wszystkie kable poprzypinane (paskami itd...) wiec chyba nie da rady... te artefakty to raczej tylko teraz... zreszta to nie byly takie artefakty jak u innych ; mam jedna fotke zaraz dam... tak sie zdarzylo chyba 1 raz...
Skymad komentarz 4 lipca 2009 komentarz 4 lipca 2009 Tak jak już Koledzy wspomnieli wyżej, jeżeli masz możliwość przetestuj kartę na innym PSU (tylko nie na tym Feelu 2 350W! BTW sam go mam :lol: ). Jeśli przetestujesz na innym, porządnym zasilaczu, który uciągnie tego GTXa i dalej będą problemy, to na Twoim miejscu oddałbym kartę na gwarancję
Qanitro komentarz 4 lipca 2009 Autor komentarz 4 lipca 2009 nastepny BSOD Microsoft ® Windows Debugger Version 6.6.0003.5Copyright © Microsoft Corporation. All rights reserved.Loading Dump File [C:\WINDOWS\Minidump\Mini070409-02.dmp]Mini Kernel Dump File: Only registers and stack trace are availableSymbol search path is: *** Invalid ******************************************************************************** Symbol loading may be unreliable without a symbol search path. ** Use .symfix to have the debugger choose a symbol path. ** After setting your symbol path, use .reload to refresh symbol locations. *****************************************************************************Executable search path is: ********************************************************************** Symbols can not be loaded because symbol path is not initialized. ** ** The Symbol Path can be set by: ** using the _NT_SYMBOL_PATH environment variable. ** using the -y <symbol_path> argument when starting the debugger. ** using .sympath and .sympath+ **********************************************************************Unable to load image ntoskrnl.exe, Win32 error 2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeWindows XP Kernel Version 2600 (Service Pack 2) MP (4 procs) Free x86 compatibleProduct: WinNt, suite: TerminalServer SingleUserTSKernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700Debug session time: Sat Jul 4 17:35:38.562 2009 (GMT+2)System Uptime: 0 days 0:41:17.587********************************************************************** Symbols can not be loaded because symbol path is not initialized. ** ** The Symbol Path can be set by: ** using the _NT_SYMBOL_PATH environment variable. ** using the -y <symbol_path> argument when starting the debugger. ** using .sympath and .sympath+ **********************************************************************Unable to load image ntoskrnl.exe, Win32 error 2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeLoading Kernel Symbols....................................................................................................................Loading User SymbolsLoading unloaded module list...........*** WARNING: Unable to verify timestamp for hal.dll*** ERROR: Module load completed but symbols could not be loaded for hal.dll******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************Use !analyze -v to get detailed debugging information.BugCheck 9C, {0, b834c050, b627c000, 135}***** Kernel symbols are WRONG. Please fix symbols to do analysis.Followup: MachineOwner--------- moze zrobic jeszcze raz test w 3dmarku (robilem juz kilka 2-3 dni temu i oczywiscie zero problemow...) ?
Gość komentarz 4 lipca 2009 komentarz 4 lipca 2009 Strasznie dziwny ten artefakt, nie mam pomysłu od czego on jest . Masz tu parę, trochę starych: http://www.playtool.com/pages/artifacts/artifacts.html Twój nie jest do żadnego z nich podobny. W szczególności nie wygląda to na problem z VRAMem, a to raczej najczęstsza przyczyna padania kart. Myślę trochę nad problemem z kompatybilnością płyta - karta (przyznam, że trochę mnie ten ASRock zastanawia ), ale jeżeli kiedyś było ok, to powinno być nadal. Zastanów się jeszcze raz czy nie będziesz miał możliwości skombinowania jakiegoś sprzętu na którym mógłbyś to diagnozować.
Qanitro komentarz 4 lipca 2009 Autor komentarz 4 lipca 2009 (edytowane) niezly ten artefakt nie ?XDDDDDDDD Jakis obrazek sie wyswietlil z kosmosu :X nie mam nic i nie mialem z tych artefaktow co podales... wiec karta nie moze byc uszkodzona... dziwi mnie, ze format nie pomogl... wyglada na to jakby sie cos gryzlo? ale jeżeli kiedyś było ok, to powinno być nadal. no wlasnie; undercover na 1600x1200 chodzil bez przycinki , antyalising , wszystko na maxa...
Gość komentarz 4 lipca 2009 komentarz 4 lipca 2009 dziwi mnie, ze format nie pomogl... wyglada na to jakby sie cos gryzlo? Dokładnie tak to wygląda. Mógłbyś sprawdzić OCCT i Furmarka?
Qanitro komentarz 4 lipca 2009 Autor komentarz 4 lipca 2009 (edytowane) pojawilo sie dzis na forum klika podobnych tematow, ktore opisuja ten blad - nie jestem sam... czyzby jakas epidemia? w furmarku dac stability test ta? x tream burning mode zaznaczyc? w furmarku dalem 1280x1024 i antyalising x16 ; test pochodzil 2 minuty i sie zawiesil, nie bylo BSOD'a ale minidump jest;> - zaraz wrzuce; ZERO ARTEFAKTOW, temp max 83oC - wentylator przyspieszyl prace dopiero od tej temp. i juz nie wzrosla; fps max 25 i co ty na to Nud? juz daje Minidumpa Microsoft ® Windows Debugger Version 6.6.0003.5Copyright © Microsoft Corporation. All rights reserved.Loading Dump File [C:\WINDOWS\Minidump\Mini070409-03.dmp]Mini Kernel Dump File: Only registers and stack trace are availableSymbol search path is: *** Invalid ******************************************************************************** Symbol loading may be unreliable without a symbol search path. ** Use .symfix to have the debugger choose a symbol path. ** After setting your symbol path, use .reload to refresh symbol locations. *****************************************************************************Executable search path is: ********************************************************************** Symbols can not be loaded because symbol path is not initialized. ** ** The Symbol Path can be set by: ** using the _NT_SYMBOL_PATH environment variable. ** using the -y <symbol_path> argument when starting the debugger. ** using .sympath and .sympath+ **********************************************************************Unable to load image ntoskrnl.exe, Win32 error 2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeWindows XP Kernel Version 2600 (Service Pack 2) MP (4 procs) Free x86 compatibleProduct: WinNt, suite: TerminalServer SingleUserTSKernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700Debug session time: Sat Jul 4 18:00:43.890 2009 (GMT+2)System Uptime: 0 days 0:24:29.906********************************************************************** Symbols can not be loaded because symbol path is not initialized. ** ** The Symbol Path can be set by: ** using the _NT_SYMBOL_PATH environment variable. ** using the -y <symbol_path> argument when starting the debugger. ** using .sympath and .sympath+ **********************************************************************Unable to load image ntoskrnl.exe, Win32 error 2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeLoading Kernel Symbols.................................................................................................................Loading User SymbolsLoading unloaded module list...........Unable to load image nv4_mini.sys, Win32 error 2*** WARNING: Unable to verify timestamp for nv4_mini.sys*** ERROR: Module load completed but symbols could not be loaded for nv4_mini.sys******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************Use !analyze -v to get detailed debugging information.BugCheck 100000EA, {86526870, 865112c8, b84ebcbc, 1}***** Kernel symbols are WRONG. Please fix symbols to do analysis.Unable to load image watchdog.sys, Win32 error 2*** WARNING: Unable to verify timestamp for watchdog.sys*** ERROR: Module load completed but symbols could not be loaded for watchdog.sys**************************************************************************** ****** ****** Your debugger is not using the correct symbols ****** ****** In order for this command to work properly, your symbol path ****** must point to .pdb files that have full type information. ****** ****** Certain .pdb files (such as the public OS symbols) do not ****** contain the required information. Contact the group that ****** provided you with these symbols if you need this command to ****** work. ****** ****** Type referenced: watchdog!_DEFERRED_WATCHDOG ****** ****************************************************************************Probably caused by : nv4_mini.sys ( nv4_mini+4d1d7 )Followup: MachineOwner--------- ewidentnie wywalaja stery karty graf... hmm moze wlozyc karte do drugiego slotu pcie ? tyle, ze wtedy bym musial wyjac karte dzwiekowa z pci... dlatego czy jest szansa, ze to pomoze? wracaj tu Nud!
Gość komentarz 4 lipca 2009 komentarz 4 lipca 2009 Sorka, że mnie nie było, musiałem się przejść do sklepu. pojawilo sie dzis na forum klika podobnych tematow, ktore opisuja ten blad - nie jestem sam... czyzby jakas epidemia? No, wywalanie sterowników zarówno NV/ATI jest dość powszechne, sam raz to miałem. Doinstalowałem wtedy SP1 do Visty i podwyższyłem napięcie RAMu, nie wiem co pomogło . w furmarku dac stability test ta? x tream burning mode zaznaczyc? Stability oczywiście, co do Xtreme Burning to bym się zastanowił - u mnie efektu to nigdy nie dawało, chyba nawet niższe były temperatury, czuję, że to raczej jest dla kart ATI . ZERO ARTEFAKTOW, Czyli raczej z GPU wszystko ok, powinno sypać od razu, choć warto by jeszcze sprawdzić ATITool'a, bo Furmark na samych shaderach jedzie. tyle, ze wtedy bym musial wyjac karte dzwiekowa z pci... Hehe, nie chwaliłeś się nią . Fajnie byłoby jakbyś w ogóle ją na jakiś czas wyjął - zawsze ciągnie trochę energii, no i w ekstremalnych sytuacjach może powodować problem, choć szczerze wątpię aby to pomogło. hmm moze wlozyc karte do drugiego slotu pcie ? Nie wiem z jaką prędkością będzie działał . I nie sądzę, aby to coś dało.
Qanitro komentarz 4 lipca 2009 Autor komentarz 4 lipca 2009 teraz dziala x4, nawet o tym nie pomyslalem , nie testuje nawet bo to nie ma sensu. juz jestem - musialem drugi raz kompa otwierac bo hdd nie podlaczylem - omg odlaczylem ta karte muzyczna ( i tak z niej teraz nie korzystalem), zrobie zaraz jakies testy i powiem czy cos pomoglo oprocz tego pod pci mam teraz karte bezprzewodowa podlaczona, ktora musi byc i ktora mysle nie przeszkadza;) //raczej nie //Nudziarz tak jak sie spodziwalem, nic to nie dalo gra wywalila bsod prawie odrazu... minidump'a po sobie nie zostawil, wiec nie wrzuce... co jeszcze mozna zrobic Nud? hmmm moze zainstalowac stery do proca , plyty glownej itp? sprobuje, na pewno nie zaszkodzi... w koncu cos sie gryzie
Gość komentarz 4 lipca 2009 komentarz 4 lipca 2009 To o czym pisałem wcześniej. Przekładankę części z innym komputerem. Nie mam więcej pomysłów, ale może ktoś coś wymyśli...
Qanitro komentarz 4 lipca 2009 Autor komentarz 4 lipca 2009 Microsoft ® Windows Debugger Version 6.6.0003.5Copyright © Microsoft Corporation. All rights reserved.Loading Dump File [C:\WINDOWS\Minidump\Mini070409-04.dmp]Mini Kernel Dump File: Only registers and stack trace are availableSymbol search path is: *** Invalid ******************************************************************************** Symbol loading may be unreliable without a symbol search path. ** Use .symfix to have the debugger choose a symbol path. ** After setting your symbol path, use .reload to refresh symbol locations. *****************************************************************************Executable search path is: ********************************************************************** Symbols can not be loaded because symbol path is not initialized. ** ** The Symbol Path can be set by: ** using the _NT_SYMBOL_PATH environment variable. ** using the -y <symbol_path> argument when starting the debugger. ** using .sympath and .sympath+ **********************************************************************Unable to load image ntoskrnl.exe, Win32 error 2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeWindows XP Kernel Version 2600 (Service Pack 2) MP (4 procs) Free x86 compatibleProduct: WinNt, suite: TerminalServer SingleUserTSKernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700Debug session time: Sat Jul 4 20:22:30.703 2009 (GMT+2)System Uptime: 0 days 0:13:06.720********************************************************************** Symbols can not be loaded because symbol path is not initialized. ** ** The Symbol Path can be set by: ** using the _NT_SYMBOL_PATH environment variable. ** using the -y <symbol_path> argument when starting the debugger. ** using .sympath and .sympath+ **********************************************************************Unable to load image ntoskrnl.exe, Win32 error 2*** WARNING: Unable to verify timestamp for ntoskrnl.exe*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exeLoading Kernel Symbols...........................................................................................................Loading User SymbolsLoading unloaded module list............Unable to load image Npfs.SYS, Win32 error 2*** WARNING: Unable to verify timestamp for Npfs.SYS*** ERROR: Module load completed but symbols could not be loaded for Npfs.SYS******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************Use !analyze -v to get detailed debugging information.BugCheck 1000008E, {c000001d, 805347d2, b00dcbbc, 0}***** Kernel symbols are WRONG. Please fix symbols to do analysis.Probably caused by : hardware ( Npfs+10a7 )Followup: MachineOwner--------- //brak pomysłów //Nud Mam pomysl i to chyba dobry! Skoro wywalaja stery od grafiki to znaczy, ze trzeba je wywalic i wsadzic cos innego. Przypomnialem sobie, ze istnieja tez stery od Omegi - z konca 2007 roku (odpowiedniki forceware 169), ale jest szansa ze bedzie wszystko dobrze (oby bylo). Juz sciagam, dam znac jak poszlo. Mysle, ze NVIDIA wypusci nowe niedlugo i nie bedzie takich problemow... - na forum juz jest z 5 takich tematow. Z jednej strony sie ciesze - oznacza to, ze z kompem raczej wszystko ok, z drugiej caly dzien marnuje siedzac, czytajac i myslac. Zaraz sprawdze te stery od Omegi i dam znac jak poszlo:) Co o tym sadzisz Mr. Nud?
Gość komentarz 4 lipca 2009 komentarz 4 lipca 2009 idea.gif Mam pomysl i to chyba dobry! Skoro wywalaja stery od grafiki to znaczy, ze trzeba je wywalic i wsadzic cos innego. Przypomnialem sobie, ze istnieja tez stery od Omegi - z konca 2007 roku (odpowiedniki forceware 169), ale jest szansa ze bedzie wszystko dobrze (oby bylo).Juz sciagam, dam znac jak poszlo. Mysle, ze NVIDIA wypusci nowe niedlugo i nie bedzie takich problemow... - na forum juz jest z 5 takich tematow. Z jednej strony sie ciesze - oznacza to, ze z kompem raczej wszystko ok, z drugiej caly dzien marnuje siedzac, czytajac i myslac. Zaraz sprawdze te stery od Omegi i dam znac jak poszlo:) Co o tym sadzisz Mr. Nud? Że za długo dzisiaj przed kompem siedzisz . Pierwsze primo: Omegi na Forceware 169 Ci nie zadziałają, to są stery z czasów 8800GTS 512 MB . Drugie primo: prawdopodobnie to nie jest wina sterownika. Trzecie primo: Omegi też są oparte o Forceware, i błędów typu wysypywanie się raczej nie naprawią. Czwarte primo: jak chcesz zmodyfikowane sterowniki to poszukaj sobie sterów od sideband'a.
Qanitro komentarz 4 lipca 2009 Autor komentarz 4 lipca 2009 (edytowane) ok, zaraz poszukam sideband // http://side.pl.pl Że za długo dzisiaj przed kompem siedzisz . dziwisz sie? doprowadza mnie to do bialej goraczki! nowy komputer!;/ moga byc te: http://forums.guru3d.com/showthread.php?p=3178687 ? kk, tu sa najnowsze, juz pobieram http://www.side.pl.pl/strona/?site=11 jeszcze 10 mb, myslisz, ze to pomoze? stery od karty wywalaja bsody, wiec...
Gość komentarz 4 lipca 2009 komentarz 4 lipca 2009 dziwisz sie? doprowadza mnie to do bialej goraczki! nowy komputer!;/ Wiem coś o tym . kk, tu sa najnowsze, juz pobieram http://www.side.pl.pl/strona/?site=11 Ok, ściągnij je. 190.15 powinny się dość mocno różnić od współczesnych sterowników, więc błędy mogą być inne . Nie chciałbym Cię martwić, ale skoro zmieniłeś system, a problem się powtarza, to pewnie to kwestia sprzętowa...
Qanitro komentarz 5 lipca 2009 Autor komentarz 5 lipca 2009 (edytowane) więc błędy mogą być inne .to pewnie to kwestia sprzętowa... dzieki, dzieki Tobie nie bede mogl spac...//nie przeze mnie masz te BSODy //Nud restart systemu musze, zaraz dam znac jak poszlo:) ok stery jak stery, normalny panel nvidia;) zaraz odpale undercover... przed chwila gralem 7 minut i nic ! - rekord juz dzis nie mam na to sily, jutro jeszcze przetestuje, jezeli sie udalo to wielbie Cie Nud! ;D Jutro sie okaze - zobaczymy, pogram 30 minut i napisze. //będę trzymał kciuki //Nud gralem , gralem 10 min, nfs sie wylaczyl, bez BSOD'a , firefox troche glupial (wylaczal sie) w panelu NVIDIA ten obrazek mruga - raz jest dobrze, a za chwile bug. - to wszystko gdy sie nfs wylaczyl, czyli problem nadal w pewnym sensie istnieje..;/ po restarcie wszystko jest normalnie... Furmark - zero artefaktow itp. , ale po 3 minutach sie zawiesza...
Skymad komentarz 5 lipca 2009 komentarz 5 lipca 2009 Może szukamy nie w tym miejscu? Spróbuj zresetować BIOS? Sprawdzić czy wszystkie kabelki są na 100% dobrze podłączone? Wysypuje się na różnych systemach, sterownikach, więc bym obstawiał, że karta jest uszkodzona fizycznie. A spróbuj jak będzie się zachowywać karta pod Linuxem?
Gość komentarz 5 lipca 2009 komentarz 5 lipca 2009 Wysypuje się na różnych systemach, sterownikach, więc bym obstawiał, że karta jest uszkodzona fizycznie. Możliwe, tylko, że to wcale nie musi być karta... Spróbuj zresetować BIOS? Sprawdzić czy wszystkie kabelki są na 100% dobrze podłączone? Można to zrobić, choć byłbym sceptyczny co do tego pomysłu . A spróbuj jak będzie się zachowywać karta pod Linuxem? To raczej kwestia sprzętowa, zresztą pod Lin. trudno będzie uzyskać porządne obciążenie karty, no chyba, że ma pod ręką jakieś gry idsoftware .
Skymad komentarz 5 lipca 2009 komentarz 5 lipca 2009 (edytowane) To raczej kwestia sprzętowa No to zostaje gwarancja (w końcu po to ona jest ).
Qanitro komentarz 6 lipca 2009 Autor komentarz 6 lipca 2009 (edytowane) zaraz zrobie restart zworka CMOS - zobaczymy czy cos da (i tak mam w biosie zapisany profil z ustawieniami, wiec sobie do nich powroce) tylko, ze [jezeli cokolwiek rzeczywiscie jest] mogloby byc uszkodzone...? ?? robilem test w atitoolu dodatkowo, zero artefaktow; karta na 99% nie jest uszkodzona... przed chwila gdy ogladalem film na YT (raczej malo obciazajaca sprzet czynnosc) komp sie zawiesil - dzwiek tez, musialem dac restart. od czasu gdy zainstalowalem stery od sindbada BSOD\'ow juz nie ma , ale gra sie albo wylacza , albo komp sie zawiesza oczywiscie , zero artefaktow, poprostu sie zawiesil macie jeszcze jakies pomysly? w tej chwili wylaczylem powiadamianie o bledach i bsodow nie ma , ale jak mowilem komp sie zawiesza, lub gra sie wylacza. pogralem pare minut w nfs undercover, gra sie wylaczyla i takie cos: to, ze ustawila sie inna rozdzielsczosc to bylo spowodowane na 90% tym ze w NFS mialem 1280 a pulpit 1600 i po prostu zglupialo...;/ //brak pomysłów, ale jutro jeszcze się nad tym zastanowię, //dzisiaj coś mi słabo myślenie idzie //Nud sprawdzilem w podgladzie zdarzen - jest to blad 0000009c ; moze uda mi sie cos wygooglowac... Microsoft ® Windows Debugger Version 6.6.0003.5Copyright © Microsoft Corporation. All rights reserved. Loading Dump File [C:\WINDOWS\Minidump\Mini070609-03.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: *** Invalid *** **************************************************************************** * Symbol loading may be unreliable without a symbol search path. * * Use .symfix to have the debugger choose a symbol path. * * After setting your symbol path, use .reload to refresh symbol locations. * **************************************************************************** Executable search path is: ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y <symbol_path> argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Unable to load image ntoskrnl.exe, Win32 error 2 *** WARNING: Unable to verify timestamp for ntoskrnl.exe *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe Windows XP Kernel Version 2600 (Service Pack 2) MP (4 procs) Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700 Debug session time: Mon Jul 6 10:49:39.515 2009 (GMT+2) System Uptime: 0 days 0:05:32.543 ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y <symbol_path> argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Unable to load image ntoskrnl.exe, Win32 error 2 *** WARNING: Unable to verify timestamp for ntoskrnl.exe *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe Loading Kernel Symbols .................................................................................................... ............. Loading User Symbols Loading unloaded module list ......... *** WARNING: Unable to verify timestamp for hal.dll *** ERROR: Module load completed but symbols could not be loaded for hal.dll ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 9C, {0, b834c050, b66b4000, 145} ***** Kernel symbols are WRONG. Please fix symbols to do analysis. Followup: MachineOwner --------- Nastąpił ponowny rozruch komputera po operacji wykrywania błędów. Wyniki tej operacji były następujące: 0x0000009c (0x00000000, 0xb834c050, 0xb66b4000, 0x00000145). Zrzut zapisano w: C:\WINDOWS\Minidump\Mini070609-03.dmp.Aby znaleźć więcej informacji, zobacz http://go.microsoft.com/fwlink/events.asp w Centrum pomocy i obsługi technicznej.
Psycholandia komentarz 6 lipca 2009 komentarz 6 lipca 2009 http://support.microsoft.com/kb/329284/pl masz podkręcony procesor, może tu leży przyczna
Qanitro komentarz 6 lipca 2009 Autor komentarz 6 lipca 2009 jak resetuje bios do default settings to nadal to samo...
Psycholandia komentarz 6 lipca 2009 komentarz 6 lipca 2009 Pamięci testowałeś? Jeśli nie to wypal program Memtest86 na płytę, reset, F11 i niech przez noc się przetestuje. Jeśli będą sprawne to coś z procesorem może być nie tak i będziesz musiał na gwarancję oddać.
Qanitro komentarz 6 lipca 2009 Autor komentarz 6 lipca 2009 Jeśli będą sprawne to coś z procesorem może być nie tak i będziesz musiał na gwarancję oddać. a dlaczego proc? a nie plyta/karta?
